How to connect remote MCP servers in Dropbox
Updated Nov 04, 2026
This article applies to all Dropbox users.
You can connect a remote MCP (Model Context Protocol) server to use information and tools from another service in Dropbox. With a connected MCP server, you can ask questions, summarize content, or request actions, depending on what the connected server supports.
In Dropbox, a remote MCP server lets Dropbox work with a service that doesn’t have a built-in connector. For example, you can use information from that service to answer a question without switching apps.
Remote MCP servers are supplied and maintained by third parties. Some can retrieve information, while others can also take actions. What Dropbox can access or do depends on the server and the permissions you grant.
Before you connect a remote MCP server
Get the server URL and setup instructions from the service provider. The service must offer a compatible remote MCP server.
Check whether your team admin allows the server you want to add. Admins can disable remote MCP use or limit which server domains your team can connect to.
Review the provider’s authorization requirements. Depending on the service, you may need to sign in, provide an API key or access token, or request admin approval.
How to connect a remote MCP server
  1. Log in to dropbox.com.
  2. Click ✗ Connect apps in the left sidebar.
  3. Click 🗀 [Connect] next to Remote MCP Server.
  4. Use the OAuth, Pre-register OAuth, or Token method.
  5. Click Connect.
  6. A window will pop up and the following steps will be dependent on the the app you’re trying to connect.
How to manage a remote MCP connection
You can manage your remote MCP connections, including editing, removing, or adding an another connection, by following these steps:
  1. Click ✗ Connect apps
  2. Click My apps
  3. Click ☑ next to Remote MCP Server
  4. Then select your action
Why a request may not work
A connected server may not support the task you request, or the task may require additional permissions. The server provider is responsible for its tools and their availability. If an action is unsupported, unavailable, or fails, Dropbox explains the limitation or failure.
Was this article helpful?
Thanks for letting us know!
Thanks for your feedback!
