Add files to your Dropbox
On your computer
Drag and drop files into the Dropbox folder on your desktop. Or, use the Save As... menu option in most applications to save files directly to your Dropbox folder.
Files in your Dropbox folder will automatically sync to dropbox.com and to your other connected devices.
Select the operating system you use to learn more.
Macintosh
After installing the desktop app, the Dropbox folder is created inside the Home folder. It may also appear in your Favorites list in the Finder.
Drag files directly into your Dropbox folder.
Win7/Win8/Win10
After installing the desktop app, the Dropbox folder is located inside the folder with your user name (such as C:\Users\Panda\Dropbox). It may also appear in your Favorites list in Windows Explorer. Another easy way to open the folder is to click the Dropbox icon in your system tray and then click Dropbox Folder in the pop-up panel.
Add files directly to your Dropbox.
On dropbox.com
  1. Sign in to dropbox.com.
  2. Click Upload.
  3. Choose Files or Folder.
    • If you choose Files, select as many files as you like and click Open.
    • If you choose Folder, select a folder and click Upload.
Note: Each file or folder that you upload through dropbox.com must be 50 GB or smaller. For larger files or folders, use the desktop or mobile apps, which don’t have a file size limit.
Svar fra nettsamfunnet
