Connected application settings in Dropbox DocSend
Updated Dec 02, 2025
The information in this article applies to customers on all DocSend plans.
Overview
You can connect to a handful of external applications as a way of streamlining your experience. Connecting these apps will enable you to log in, sync data, and more.
On DocSend you can manage the following third-party applications:
  • Sign-In Methods
    • Dropbox
    • Google
    • LinkedIn
  • External Cloud Storage
    • Dropbox
    • Google Drive
    • OneDrive
    • Box
    • Egnyte
    • SharePoint
  • Other Connected Apps
    • Salesforce
    • Join.me
Learn more about external cloud storage providers.
warning icon
Important: Salesforce is only available for Standard plans and above.
Connect third-party applications
To connect to an available third-party application, follow the steps below:
  1. Navigate to your Settings page.
  2. Go to the Connected Apps page.
  3. Click Connect under the application you wish to connect.
  4. You’ll be redirected to the login page. Enter your credentials and click Allow to connect that application.
Your DocSend account is now directly linked to your desired application.
Disconnect third-party applications
To disconnect from any connected third-party applications, follow the steps below:
  3. Click Disconnect under the application you wish to disconnect.
  4. You’ll be redirected to the login page. Enter your credentials and click Allow to disconnect that application
Things to consider
Was this article helpful?
Thanks for letting us know!
Thanks for your feedback!
