How to test Dropbox Sign API callback errors
Updated Nov 25, 2025
You can manually trigger automatic callback examples for error events by including these codes in the signer's email address of your tests:
Overlay Error
[any letters and/or numbers]+overlayerror@hellosign.com
Here's an example of an Overlay Error callback - note the "event_type" value is "file_error", as well as the "signatures"->"status_code[0]" value.
This error can occur with all Signer Placement options except the Appended Signatures Page.
Component Error
[any letters and/or numbers]+componenterror@hellosign.com
Here's an example of an Component Position error - note the "event_type" value is 'signature_request_invalid', as well as the "signatures"->"status_code[0]" value. This means the Overlay Error is specific to signer, which may help with troubleshooting your form_fields_per_documents.
Text Tag Error
[any letters and/or numbers]+doctagerror@hellosign.com
Here's an example of a Text Tag Error - note the "event_type" value is "signature_request_invalid", though the value for "signatures"->"status_code[0]" is "error_text_tag".
Recipient Declined
[any letters and/or numbers]+declined@hellosign.com
Here's an example of a Declined event - note the "signatures"->"status_code[0]". Also, for this test the "signatures"->"decline_reason[0]" is null, but the signer would be required to fill in a reason, so you'd typically get a string returned for the "decline_reason".
Unknown Error
[any letters and/or numbers]+unknownerror@hellosign.com
Here's an example of an Unknown Error.
Was this article helpful?
Thanks for letting us know!
Thanks for your feedback!
