You can connect your Google or Outlook calendar and contacts to your Dropbox account. The calendar integration allows you to view upcoming meetings, join meetings, and attach files to meetings right from your desktop.
Some users have access to the new App Center. If you see App Center when you click the grid icon in the top-right corner of your homepage, follow the instructions below to connect your Google or Outlook calendar and contacts to your Dropbox account.
- Sign in to dropbox.com.
- Click the grid icon in the top-right corner.
- Click App Center from the menu that appears.
- Click Google Calendar or Outlook Calendar and Contacts.
- If you don’t see Google Calendar or Outlook Calendar and Contacts, use the App Center search bar.
- Click Connect, and follow the prompts.
Learn more about the App Center.
To connect your Google or Outlook calendar and contacts:
- Click your profile picture (or grey circle) in the upper-right corner.
- Click Settings.
- Click the Connected apps tab.
- Next to Google or Outlook, click Connect to Google or Connect to Outlook and follow the prompts to allow access.
Join meetings from the Dropbox desktop app
Once you connect your calendar, you can access your scheduled meetings from the Dropbox desktop app. To join, you must have created a meeting with one of the following:
- Google Hangouts
- Google Meet
- Zoom
To join meetings in the Dropbox desktop app:
- Click the Dropbox icon in your taskbar (Windows) or menu bar (Mac).
- Click the For you tab to view any upcoming meetings in your Google or Outlook calendar.
- Note: Meetings will appear 5 minutes before the meeting begins and remain 10 minutes after it ends
- Click Join Zoom meeting, Join Google Hangouts, or Join Google Meet to join your meeting.
Attach files to your meetings from the desktop app
You can attach files to your meetings right from your desktop.
To attach a file to a meeting:
- Click Attach below the meeting you’d like to attach a file to.
- Dropbox may also make file attachment Suggestions, which appear under the meeting name
- Click the file you’d like to attach.
- Click OK (Windows) or Select (Mac).
- You can attach up to three files to a meeting
To take meeting notes in a Dropbox Paper template, click the downward-facing arrow next to Attach, and click Take notes.
Can others see my attached files?
If the other participants of the meeting have access to the file you attach through Dropbox sharing permissions, it will also appear in their For you tab. Otherwise, only you can see it.
Disconnect your Google or Outlook calendar and contacts from Dropbox
To disconnect your Google or Outlook calendar:
- Click your profile picture (or face icon) in the upper-right corner.
- Click Settings.
- Click Disconnect.
