How to migrate Dropbox Sign from sandbox to production
Updated Dec 04, 2025
It's always best practice to test in a sandbox. This includes testing apps such as Dropbox Sign for Salesforce. Once you've properly tested and verified functionality is working correctly there are a few steps to migrate functionality from a sandbox to your production environment. To complete this migration, follow the steps below:
STEPS to Connect to Production
  1. Disconnect Dropbox Sign account from Sandbox in Dropbox Sign settings.
  2. Connect Dropbox Sign account to Salesforce production environment.
  3. Assign permission sets and modify page layouts either manually or via a change set from your sandbox.
STEPS to Transfer Dropbox Sign Templates
  1. Use a Salesforce export tool to pull the Dropbox Sign Template records (HelloSign__Template__c) from your sandbox that you want in production.
  2. Use a Salesforce export tool to pull the Dropbox Sign Signer Role records (HelloSign__SignerRole__c) from your sandbox that lookup to the templates you are migrating.
  3. Insert the Dropbox Sign Template records into production.
  4. Inserting Dropbox Sign Template records will create a success csv file which contains the newly inserted record IDs.
  5. On your Dropbox Sign Signer Role export file replace the Dropbox Sign Template lookup ID filed with the record IDs on the success csv file. A vlookup formula using the sandbox record IDs will allow you to map the new ids to the correct records.
  6. Insert the Dropbox Sign Signer Role records (with newly mapped Template lookup IDs) into production.
Was this article helpful?
Thanks for letting us know!
Thanks for your feedback!
