Actualización May 16, 2025
    • Follow-up emails
    • Financial summaries
    • Project proposals
    • Action item lists
    To write new content:
    1. Log in to dash.ai.
    3. Click Write something.
    7. Click arrow-up (send).
      • Copy text
      • Copy markdown
      • Save to Paper
    9. Click add Create Template.
    11. Click Next.
    13. Click Next.
    How to create a custom tone
    11. Click Next.
    13. Click Next.
    15. Select the permissions:
    16. Click Done.
    Respuestas de la comunidad
