Actualizada May 16, 2025
  • Follow-up emails
  • Financial summaries
  • Project proposals
  • Action item lists
To write new content:
  1. Log in to dash.ai.
  3. Click Write something.
  7. Click arrow-up (send).
    • Copy text
    • Copy markdown
    • Save to Paper
  9. Click add Create Template.
  11. Click Next.
  13. Click Next.
How to create a custom tone
  11. Click Next.
  13. Click Next.
  15. Select the permissions:
  16. Click Done.
Respuestas de la comunidad
