Comment on a specific part of a file on Dropbox
Updated Nov 06, 2023
You can comment on a specific part of a file if you're on dropbox.com and working on a supported file type. To do so:
- Open the file you want to comment on. You'll see a pop-up message that says Select an area to comment on.
- Drag to highlight the desired area.
- Click the text box that says Write a comment, type your comment, and click Post.
Learn how to comment on a video or audio file.
Learn how to edit, delete, or hide comments.
Not using Dropbox yet? See how Dropbox makes syncing files easy.
Community answers
Posted by: LanternMoon 359 days ago108020
Posted by: sr_c 383 days ago253670
Posted by: markhutch 349 days ago830130
