Status
Description |
Message |
Troubleshooting |
Error
Item limit has been reached. Some apps limit how many items can be updated at once. Select fewer items and try again.
There are too many items selected to apply fixes.
Select fewer items and retry the action again.
For Google, select less than 500,000 total items.
For Dropbox, select less than 10,000 total items.
Error
The app connection is limited.
The app has temporarily limited some actions. Try again later.
There is an issue with the app connection, but the reason is unknown.
Try again at a later time.
Error
The app connection is not active. Reconnect the app and try again. If the problem continues, check the app and its settings.
This happens with the app is disconnected. The integration required to perform this action is disconnected or not configured correctly.
Try reconnecting the integration and try again.
Error
Some access could not be removed. Some sharing access was removed, but some may still be active. This can happen if the app blocked the change or if syncing is still in progress. Try again later.
This occurs when some links or collaborators were removed, but not all.
Error
Item not found.
This occurs if an item was moved, deleted, or is not yet available.
Error
Something went wrong. There was a problem.
This happens when an unspecified error occurs.
Skipped
No permission to make this change. Permission to make this change may be controlled externally. If possible, contact the item owner or an app admin for help.
This occurs when a user with sufficient permissions was not found or when you try to perform an action on a user that's not part of the organization.
Update access in the source app.
Skipped
Cannot add collaborator. The collaborator doesn't yet have access to the selected app. Confirm they have access and try again later.
This occurs when an admin tries to add a collaborator that does not have access to selected connector.
Sometimes ingestion lag can cause delays with trying to add a collaborator to an item.
Check the collaborators’ access to the source app and try again later.
Skipped
Not allowed by app settings. The settings for this action are turned off in the app. To make this change, update the settings in the app and try again.
This specific error message occurs because the the source app is not configured to allow for this change.
Check the source app settings and try again.
Skipped
Access update not required. Access was previously updated. No further action is required.
This occurs when an account being removed was previously already removed.
Check the access in the source app and try again.
Skipped
Access update not required. The account already has access through a group. The requested action is completed.
The account already has access.
No action is needed.
Skipped
Access permission managed by top-level source. Access is managed by a folder, drive, or app that includes this item. Update access at the top-level source. If the top-level source was selected, no further action is required.
This error occurs when access is managed at the top level source (folder or drive).
Check the top level item.
If it was updated, no action is needed.
If it wasn’t updated, remove access at the top level.
Skipped
Cannot update owner access. Access for item owners and admins can't be changed until ownership is transferred to someone else.
This occurs because the system prevents owners being removed from items.
Change the owner of the item and try again.
Skipped
Action is not allowed for this top-level source. This action is not allowed for top-level source folders, sites or shared drives.
This occurs if you are trying to delete a shared drive. This action is not allowed.
Nothing further can be done in Protect and Control, but you can try this action in the source app.
Skipped
Action is not supported for this item. Can't update because the app doesn't support this action for this item.
This occurs when a connector doesn't support a certain action.
Nothing further that can be done in Protect and Control, but you can try this action in the source app.
Skipped
Action is not allowed for Microsoft 365. Microsoft 365 groups can’t be removed.
This error occurs if you try removing Microsoft 365 groups from Team sites that they were created on.
Skipped
Guest access update required. Can't complete this action while a guest link is still active. Remove guest access, then try again.
This error occurs when attempting to remove a company link when a guest link is present in Microsoft 365. Guest access in Microsoft cannot exist without the Company (Everyone group) permission.
Remove the guest link and try again.
