What is Dropbox Advanced?
Updated Jul 07, 2026
    The information in this article applies to customers on Dropbox Advanced.
    Dropbox Advanced gives teams 15 TB of total storage space, shared among the entire team (5 TB per actively-used license with a 3 license minimum), along with advanced admin, audit, security, and integration capabilities.
    Note: The maximum amount of storage space you can purchase on the Advanced plan is 1,000 TB.
    Learn more about each Dropbox plan and its features.
    What features are available to teams on Dropbox Advanced?
    The Advanced plan helps teams stay organized, focused, and work together more effectively. It has all of the features available to teams on Dropbox Standard, in addition to:
    • Storage per license: Starting at 15 TB of total storage space, shared across the team (5 TB per actively-used license with a 3 license minimum).*
      • Notes:
        • An actively-used license is when a unique person regularly logs in and uses Dropbox.
        • Inactive licenses aren't removed automatically. Certain types of admins can add or remove licenses from the admin console.
    • Large file delivery: Send files with Dropbox Transfer, with a transfer size limit of 100 GB.
    • Team controls: Manage team invitations, approve which devices team members use for work files, and access team member work accounts with sign in as a user.
    • App integrations: Use single sign-on (SSO) integrations and API calls for data migrations.
    • Admin management: Delegate team administration with access to tiered admins.
    • Security alerts and ransomware detection: Get notified of suspected threats and take action to protect your data immediately.
    • Real-time support: Contact support by phone, chat, or email.
    • Advanced key management: Encrypt your data with unique team keys and a multi-layered key encryption approach.
    • End-to-end encryption: Help prevent third parties from accessing your transferred data.
    *Some legacy Dropbox Advanced plan customers can still request additional storage space, depending on their purchase date. Requests are approved as appropriate while allowing Dropbox to manage storage responsibly.
    FAQs about Dropbox Advanced
    How much does Dropbox Advanced cost?
    The cost of Dropbox Advanced depends on several factors, including the number of members on a team and your geographic location.
    Note: The Dropbox Advanced plan requires a minimum purchase of 3 licenses.
    How can I purchase Dropbox Advanced?
    To purchase Dropbox Advanced, visit the main purchase page.
    Can I upgrade my Dropbox Standard team to Dropbox Advanced?
    Yes. If you have an existing Dropbox team account, you can migrate to the Advanced plan.
    If your team is on Dropbox Standard:
    1. Log in to dropbox.com with your admin credentials.
    2. Click Admin console.
    3. Click Billing.
    4. Under Products, click Change plan.
    5. Select Dropbox Advanced.
    6. Click Confirm.
    You’ll be charged a prorated amount when you upgrade. On your next billing period, your subscription cost will include the full price of Dropbox Advanced.
    If your team is on Dropbox Enterprise, contact our sales team to change your plan.
    What happens if my account goes over my storage space quota?
    If your Dropbox account goves over its storage space quota, then file syncing will stop. Syncing will resume after you bring your account back under your storage quota.
    Our support team may contact you and let you know that you need to remove files to get back under storage quota. If your account continues to exceed its storage quota, your account may be closed, or your files may be deleted. We’ll notify you before this happens and give you an opportunity to save your files.
    Was this article helpful?
    Thanks for letting us know!
    Thanks for your feedback!
