You can make a file available on the Android app for offline viewing by turning on the Available offline option. Specifically, this does the following:
Once you've made a file available offline, and it has downloaded to your phone or tablet, you'll be able to access it any time by tapping Offline files from the main menu, even if you aren't connected to the internet.
To remove a file from your Offline files screen, go to the file and tap the downward arrow to the right of the file’s name. Toggle the button next to Available offline to turn the feature off.
If you have your personal and business accounts connected, you'll be able to access all of your offline files from the same screen. The Offline files screen allows you to view all your files together or separate them out by account, so you can keep your personal and work data organized on the go.
To view a file anywhere and any time, make it available offline. Specifically, making a file available offline:
When viewing a single file, you can tap the ellipses icon (...) and select Make Available Offline.
Once downloaded, you'll be able to access your offline files at any time. To ensure you have the latest versions, Dropbox will update them automatically if you're on a Wi-Fi network. If you're on a cellular (3G or 4G) network and some files have changed, tap each file to open it and get the latest changes.
If you have your personal and business accounts connected, you will be able to access all of the files you have made available offline from the same tab. The Offline tab allows you to view all your offline files together, or you can view them by account type.
You can access a file anywhere, any time by marking it for offline access. Specifically, this does the following:
You can also make a file available offline while previewing it: tap the offline icon at the bottom of the screen.
Once downloaded, you'll be able to access your offline files at any time. To ensure you have the latest file versions, Dropbox will update files automatically whenever the app is open and there's a Wi-Fi connection. If you're on a cellular network (3G or 4G) and some files have changed, tap each file to open it and get the latest version.
If you have your personal and business accounts connected, you will be able to access all of the files you mark for offline access from the same tab. The Offline tab allows you to view all your offline files together, or you can view them by account.
Find out how can these lists help you access your most important files and folders in the Dropbox desktop app, mobile ap
Learn how to view the modified date for your Dropbox files and folders, what changes it and why it's different across de
