The Dropbox system extension
The Dropbox system extension is automatically installed when you install the Dropbox desktop app. It allows you to open online-only files from File Explorer/Finder or third party applications.
Notes:
  • This information is specific to users on Windows and macOS 10.15 and below.
  • Installation of the Dropbox system extension is not applicable to macOS 11 and above.
  • If you’re on a Dropbox business team, an admin on your team can restrict your ability to install or uninstall the system extension.
Install the Dropbox system extension manually
This Dropbox system extension is installed automatically when you install Dropbox desktop app, but it can sometimes be blocked by some system permissions. If this occurs, follow the instructions below to manually install the Dropbox system extension.
Uninstall the Dropbox system extension
To uninstall the system extension:
  1. Sign in to dropbox.com.
  2. Click your avatar (profile picture or initials) in the upper-right corner.
  3. Click Settings.
  4. Click the General tab.
  5. Toggle Dropbox system extension to off.
Admins: Uninstall the system extension from your team’s computers
As an admin, you can uninstall the Dropbox system extension from your team’s computers. To do this, go to the Dropbox system extension page in the admin console, check the boxes, and click Uninstall.
After the system extension is uninstalled, team members will still be able to use the Dropbox folder in File Explorer/Finder, but all of their online-only files will become available offline and the extension will be disabled for both their team account and any linked personal account they may have.
Note: Online-only files becoming available offline will result in files being downloaded directly to a team member’s computer.
Is the Dropbox system extension secure?
The Dropbox system extension is secure and only used for online-only file management. It’s similar to other drivers and system extensions you may need to install for hardware or software, like printers, hard drives, or desktop applications.
Learn more about how Dropbox keeps your files safe and secure.
How helpful was this article?
We’re sorry to hear that.
Let us know how we can improve:
Thanks for your feedback!
Let us know how this article helped:
