How to save DocSend files to your Dropbox account
Note: This feature doesn’t support saving NDAs (also known as non-disclosure agreements) to your Dropbox account. Learn about NDAs in DocSend.
How to enable/disable the auto-save feature
To enable the auto-save feature, you’ll need to give Dropbox access to your DocSend account. To do this:
- Log in to docsend.com.
- Click your avatar (profile picture or initials) in the top-right corner.
- Click Settings.
- Click Connected Apps.
- Click Connect Dropbox.
- Click the Dropbox account you’d like to connect.
Note: If you have a Dropbox account but you’re not logged into it, you’ll need to log in first. If you don’t have a Dropbox account, you’ll be asked to create one before you can connect. Learn how to create a Dropbox account.
Note: Enabling this feature won’t save past DocSend documents to your DocSend folder.
How to manually save DocSend files
You can save individual DocSend files to Dropbox without enabling auto-save. In DocSend, click the Dropbox icon next to the file you want to save. The zip file will save and then open in the DocSend folder in your Dropbox account.
Note: If the zip file doesn’t automatically open in your Dropbox account, you may be experiencing an issue caused by a third-party browser extension or add-on (such as a pop-up or ad blocker).
Community answers
Posted by: billdata 17 days ago27330
Posted by: NCMonsterTree 27 days ago23950
Posted by: Esikhoob 29 days ago43730
