Dropbox Sign for Salesforce integration FAQs
Updated Nov 18, 2026
    The information in this article applies to customers on Dropbox Sign Standard and Premium.
    Dropbox Sign for Salesforce lets you send signature requests and templates within Salesforce.
    How can I add the Dropbox Sign for Salesforce integration?
    If you already have a paid Dropbox Sign account, your organization needs to have a Dropbox Sign Enterprise plan with Salesforce activated. To buy Dropbox Sign Enterprise plan, contact Dropbox Sign Sales.
    If you have a Free Dropbox Sign account you can install Dropbox Sign for Salesforce to enrol automatically in our free 30-day Dropbox Sign for Salesforce Trial.
    Can I use the Dropbox Sign integration on any device?
    The Dropbox Sign for Salesforce integration doesn't support iPad, tablet, or other mobile devices. The document editor isn't optimized when creating templates or requesting signatures from within Salesforce. If you'd like this functionality added to the Dropbox Sign for Salesforce integration, contact Dropbox Sign support.
    Can I send documents from Salesforce via SMS?
    Yes, customers on Dropbox Sign API Standard and Premium can contact Dropbox Sign Sales to request the SMS Tools add-on.
    With that add-on, you can:
    • Send signature requests and templates by SMS directly from Salesforce.
    • Use SMS authentication to add an extra layer of security to standalone docs and templates.
    Note: To use the SMS feature in Salesforce, you need an active Dropbox Sign for Salesforce integration and an SMS Tools add-on.
    How do templates work in Salesforce?
    Templates must be created in Salesforce when using the Dropbox Sign for Salesforce integration. Any templates created on sign.dropbox.com or when using the Dropbox Sign API as a standalone product can't be used in Salesforce. Templates created on Salesforce can be used on sign.dropbox.com and the Dropbox Sign API.
    How do I use merge fields with the Dropbox Sign for Salesforce integration?
    When creating a template, you have the option of selecting certain fields to merge data. You should select from the available merge fields of your choice in the template creation flow in Salesforce when creating a template. You can also use the search bar to look for a specific field.
    Note: Not all fields are compatible with merging data. Only those that are eligible will be displayed.
    Why am I seeing an “Unauthorized API Key” error message?
    If you’re seeing the error message “isApiConnected() error Unauthorized API key”, it means that the API key to your Dropbox Sign account doesn’t match the API key that Salesforce is expecting. You can solve this by reconnecting DropboxSign to Salesforce, as follows:
    1. Log in to Salesforce.
    2. On the Dropbox Sign Settings tab, click Connect.
    3. Grant access to the Dropbox Sign integration.
    Note:
    • If you aren’t already logged in at sign.dropbox.com, you’ll see a login page.
    • If you were previously logged in with the correct account, you’ll see a confirmation and will need to click Grant.
    • If the connection was successful, you’ll see a message confirming some things to note.
    How do I create Dropbox Sign text tags in Salesforce?
    With text tags, you can add Dropbox Sign signature fields and custom fields directly into the source document. Dropbox Sign will detect the text tags in the document and display them correctly for all signers. Common use cases for text tags are when using a third-party document generation tool, or a product like Salesforce CPQ where templates are created using HTML and then converted into PDF documents. The Dropbox Sign API scans your documents automatically, so no extra steps are needed to turn on text tags when using the Dropbox Sign for Salesforce integration.
    A Dropbox Sign text tag must always be enclosed in brackets [ ] and use a pipe | between sections.
    To add Dropbox Sign text tags in Salesforce,  input the the required information in the following format:
    [ field type | required | which signer | label (object.field)]
    Note: Text tags are case sensitive. “Which signer” would be signer1, signer2, and so on. If the field isn’t required they must add “noreq” between the type and signer.
    Learn more about text tags.
    Was this article helpful?
    Thanks for letting us know!
    Thanks for your feedback!
    Community answers
