Smart Sync for team admins
This article discusses a feature that's available to Dropbox Professional and Dropbox Business customers.
Smart Sync helps you and your team share content without worrying about overloading your hard drives. Smart Sync team settings are available to Dropbox Business team admins.
When your team starts using Smart Sync, content that’s already downloaded to team member devices remains downloaded. New content is automatically online-only unless you change this setting in the Admin Console. Team members can also chose a personal default for each of their connected computers.
Подробнее о функции Умной синхронизации для участников рабочих групп.
How do I set the Smart Sync default for my team?
The Smart Sync default applies to new content after the default is enabled and isn’t retroactive. The Smart Sync default applies to:
  • Вступление в общую папку
  • Linking a new device
  • Adding new content from another computer
To set a default for your team:
  1. Войдите в свой аккаунт администратора на сайте dropbox.com.
  2. Откройте Консоль администрирования.
  3. Нажмите Настройки.
  4. Click Smart Sync.
  5. Select a default for Smart Sync:
    • Синхронизация по локальной сети
    • Только в онлайн-режиме
Note: You don’t need to set a default for team members to use Smart Sync.
While the admin setting is the initial default, team members can change their device settings to a different default.
Каковы системные требования для Умной синхронизации?
Can I manage Smart Sync settings for individual team members?
No, Smart Sync settings are team wide, or set by individual team members. Individual team members can manage their own Smart Sync settings at the device, folder, and file level.
Can I manage Smart Sync settings at a folder level?
No, the Smart Sync default applies to all folders.
Can I opt out of the system extension for my team?
Yes. Learn more about opting your team out of the system extension.
Насколько полезна была для вас эта статья?
Мы очень сожалеем.
Дайте знать, как нам улучшить свою работу:
Благодарим за отзыв!
Дайте знать, насколько полезной была эта статья:
Ответы сообщества
