Smart Sync for team admins
This article discusses a feature that's available to Dropbox Professional and Dropbox Business customers.
Smart Sync helps you and your team share content without worrying about overloading your hard drives. Smart Sync team settings are available to Dropbox Business team admins.
When your team starts using Smart Sync, content that’s already downloaded to team member devices remains downloaded. New content is automatically online-only unless you change this setting in the Admin Console. Team members can also chose a personal default for each of their connected computers.
Läs mer om Smart synkning för teammedlemmar.
How do I set the Smart Sync default for my team?
The Smart Sync default applies to new content after the default is enabled and isn’t retroactive. The Smart Sync default applies to:
  • Gå med i en delad mapp
  • Linking a new device
  • Adding new content from another computer
To set a default for your team:
  1. Logga in på dropbox.com med ditt administratörskonto.
  2. Klicka på Adminkonsolen.
  3. Klicka på Inställningar.
  4. Click Smart Sync.
  5. Select a default for Smart Sync:
    • Synkroniseras lokalt
    • Enbart online
Note: You don’t need to set a default for team members to use Smart Sync.
While the admin setting is the initial default, team members can change their device settings to a different default.
Vilka är systemkraven för smart synkning?
Can I manage Smart Sync settings for individual team members?
No, Smart Sync settings are team wide, or set by individual team members. Individual team members can manage their own Smart Sync settings at the device, folder, and file level.
Can I manage Smart Sync settings at a folder level?
No, the Smart Sync default applies to all folders.
Can I opt out of the system extension for my team?
Yes. Learn more about opting your team out of the system extension.
Var artikeln till hjälp?
Tråkigt att höra.
Tack för din feedback!
Svar från community
