This article covers basic and advanced fixes for Dropbox sync issues. If you’re experiencing syncing problems on any device, including your computer (Windows or Mac), phone (Android or iPhone), or tablet, use this article to troubleshoot.
Use this article to fix the following issues:
- Dropbox is not syncing, updating, or refreshing files, folders, or shared folders.
- Dropbox is not “downloading” or not “uploading”, meaning not syncing or updating, files.
- Dropbox appears to have stopped syncing, is no longer syncing, or is stuck indexing.
- Files are taking a long time to sync, are syncing slowly, or appear to always be syncing.
- You see a “can’t establish secure connection” error or a different sync error message.
- Dropbox has unexpectedly high CPU, memory, or RAM usage.
- You see “permission error”, “access denied”, “permission denied”, or “rejected by server”.
- You see a “Dropbox is damaged”, “OperationalError”, or “BrokenTempDirError” error.
- If your files aren’t showing up or you don’t see files that should be there, visit the selective sync feature article in addition to this article.
- If the Dropbox Smart Sync feature isn’t working as expected, visit the Smart Sync feature article in addition to this article.
- If you see a sync icon that you don’t recognize, like a gray circle with a minus sign or a red circle with an “X”, visit this sync icons article in addition to this article.
For a basic introduction to how Dropbox sync works, visit this sync overview article instead.
Not using Dropbox yet? See how Dropbox makes syncing files easy.
Basic solutions to file syncing issues
Most file syncing issues on any device can be fixed with the following solutions:
Make sure you’re looking in the right places
Here are all the places you can access your files in Dropbox:
- Dropbox.com in a web browser on your phone or computer
- Dropbox folders on your computer, which you can find in two places:
- The Dropbox mobile app on your phone or tablet
Wait a few minutes and check back
There are a lot of reasons why syncing could be temporarily delayed. For example, your device could be struggling to connect to internet or your files may be very large. Wait a few minutes and then check back.
Check your internet connection
For a file to sync, Dropbox must connect to the internet on the device where you added or changed the file, and the device where you’re trying to access it. Make sure the device you’re using is connected to the internet. If you’re using data, connect to Wi-Fi instead.
Reopen the Dropbox on your desktop or refresh dropbox.com
To restart, resync, or force sync Dropbox, close and reopen (quit and relaunch) Dropbox on your desktop or refresh (reload) dropbox.com on your device. If you added a file to the Dropbox folder in File Explorer/Finder and it’s not syncing on dropbox.com or the mobile app, make sure Dropbox is open and running on your desktop.
Close other applications that are open on your device
If Dropbox files are open in another application, they might not sync. You might see an error message indicating that your file is in use. Even if you don’t see this error, double check by closing all non-Dropbox applications.
Make sure Dropbox is up to date on your computer
Make sure you’re signed in to the right Dropbox account
Follow our filename recommendations
Restart your computer or phone
If it’s a shared file or folder, make sure you added it to your account, and that no one changed it
If a shared file or folder isn’t syncing, make sure it's added to your account. If changes to it aren’t syncing, it could have been moved, deleted, or renamed by someone you’re sharing it with. Check your account on dropbox.com to see if the file is still in its original location with its original name, or ask whoever you’re sharing the file with if they moved, deleted, or renamed it.
Advanced solutions to file syncing issues
If the above, basic solutions don’t solve your file sync issue, try some of the more-advanced solutions below.
Allow Dropbox permissions in your computer’s firewall, security, and antivirus software
- Sign in to dropbox.com.
- Click on the Apple menu (Apple icon) in the top left corner of the menu bar.
- Click System Preferences.
- Click Security & Privacy.
- Click on the Privacy tab.
- Click on the lock icon in the bottom left corner, and enter your Mac username and password to allow changes.
- Scroll down and click Full Disk Access.
- Check the box beside Dropbox.
- Click Later on the screen that pops up.
- Select Accessibility.
- Restart Dropbox on your desktop to apply these changes.
Check if the internet you’re trying to connect to has security restrictions
If the Dropbox folders are on an external hard drive, check your connection
If the Dropbox folders you want to sync are on an external hard drive, make sure the external hard drive is connected and recognized by your computer. If it’s connected and recognized, and you’re still having syncing issues, move the Dropbox folder back to your computer temporarily to see if the external hard drive is causing the issue. Contact support if this is the case.
Uninstall and reinstall Dropbox on your desktop
Make sure you’re not trying to sync a file that Dropbox can’t sync
Make sure Dropbox supports your device and operating system
Check our system requirements article to make sure the device and operating system you’re using are supported by Dropbox. If it’s not, update your operating system or use a different device.
Make sure you’ve saved any changes back to Dropbox
If a file isn’t updating, and you made a change to it in a different non-Dropbox application, double check that your changes saved back to Dropbox. Some applications automatically save your changes back to Dropbox, while others need to be saved back manually. You may also have saved it somewhere else on your computer. Search your computer for the file with the search bar in your taskbar (Windows) or Spotlight in your menu bar (Mac).
Make sure your devices’s date and time settings are accurate
Make sure the file isn’t read-only (Windows) or locked (Mac)
See if you’re out of disk space on your computer and free up space
Update or reinstall any non-Dropbox applications you’re using
If you’re making changes to files in Dropbox with a non-Dropbox application, make sure those applications are up to date or uninstall and reinstall them.
